Zum Hauptinhalt wechseln
Samsung Chromebook XE550C22 RAM Replacement
Was du brauchst
  1. Samsung Chromebook XE550C22 RAM Replacement, Back Panel: Schritt 1, Bild 1 von 3 Samsung Chromebook XE550C22 RAM Replacement, Back Panel: Schritt 1, Bild 2 von 3 Samsung Chromebook XE550C22 RAM Replacement, Back Panel: Schritt 1, Bild 3 von 3
    • Turn the power off before beginning this step.
    • Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
  2. Samsung Chromebook XE550C22 RAM Replacement: Schritt 2, Bild 1 von 2 Samsung Chromebook XE550C22 RAM Replacement: Schritt 2, Bild 2 von 2
    • Remove the eight 7mm screws using the J0 Screwdriver.
  3. Samsung Chromebook XE550C22 RAM Replacement: Schritt 3, Bild 1 von 3 Samsung Chromebook XE550C22 RAM Replacement: Schritt 3, Bild 2 von 3 Samsung Chromebook XE550C22 RAM Replacement: Schritt 3, Bild 3 von 3
    • Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
    • Continue prying around the sides to release more brackets.
  4. Samsung Chromebook XE550C22 RAM Replacement: Schritt 4, Bild 1 von 2 Samsung Chromebook XE550C22 RAM Replacement: Schritt 4, Bild 2 von 2
    • After deconnecting all the brackets, pull the back panel away from the laptop.
    • Note: The back panel has some flex to it, don't be afraid to use some force.
  5. Samsung Chromebook XE550C22 RAM Replacement, Battery: Schritt 5, Bild 1 von 2 Samsung Chromebook XE550C22 RAM Replacement, Battery: Schritt 5, Bild 2 von 2
    • Remove the four 3mm screws holding the battery with the J0 screwdriver.
  6. Samsung Chromebook XE550C22 RAM Replacement: Schritt 6, Bild 1 von 2 Samsung Chromebook XE550C22 RAM Replacement: Schritt 6, Bild 2 von 2
    • Lift the battery up at an angle to disconnect the battery from the motherboard, then pull it away from the laptop.
    • Do not lift the battery straight up. This will damage the battery's connectors.
  7. Samsung Chromebook XE550C22 RAM Replacement, RAM: Schritt 7, Bild 1 von 1
    • Locate the RAM on the middle right side of the Chromebook.
  8. Samsung Chromebook XE550C22 RAM Replacement: Schritt 8, Bild 1 von 2 Samsung Chromebook XE550C22 RAM Replacement: Schritt 8, Bild 2 von 2
    • Using your fingers, separate the silver clips that are holding the RAM in place on each side.
    • The RAM will "pop-up" on its own after separating clips.
  9. Samsung Chromebook XE550C22 RAM Replacement: Schritt 9, Bild 1 von 2 Samsung Chromebook XE550C22 RAM Replacement: Schritt 9, Bild 2 von 2
    • Pull the RAM away from the Chromebook.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Abel Osorio
330 Reputation
2 Anleitungen geschrieben
CSU Fullerton, Team S2-G7, Bruce Fall 2017 Mitglied von CSU Fullerton, Team S2-G7, Bruce Fall 2017
CSUF-BRUCE-F17S2G7
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 690
