Einleitung
This guide can be use to replace a faulty wifi card or to upgrade the wifi connection bandwidth of a Samsung Chromebook XE550C22
Was du brauchst
Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
Continue prying around the sides to release more brackets.
Remove the four 3mm screws holding the battery with the J0 screwdriver.
Lift the battery up at an angle to disconnect the battery from the motherboard, then pull it away from the laptop.
Remove the 6mm screw from the top right corner of the card using the J0 screwdriver.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
