Einleitung
This guide shows how to replace the back buttons panel of a Samsung DV180F when damaged. This procedure is very simple since the device is not entirely disassembled. It only involes loosening a few screws and unpluging the connecting ribbons.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Remove the two external screws from the camera using a Phillips 000 screwdriver.
Insert a plastic opening tool in the gap between the camera body and back panel.
Pry along the right side of the camera to separate the back panel.
Once the camera is open, remove the two internal screws using a Phillips 000 screwdriver.
Use a plastic opening tool to release the lock securing the ribbon receptor to the right side of the motherboard.
Gently lift the circuit board from the camera.
Remove the display ribbon receptor lock to remove back panel from the motherboard.
