Einleitung
This guide will show how to remove the Back LCD Screen.
Was du brauchst
Remove the two black 4.2 mm screws on the right side of the camera using a Phillips #0 screwdriver.
Remove the two black 4.2 mm screws on the left side of the camera using a Phillips #0 screwdriver.
Remove the two black 4.2 mm screws on the bottom of the camera using a Phillips #0 screwdriver.
Remove the front case of the camera.
Remove the front LCD screen from the front case next to the lens.
Flip the black tab where the back LCD screen connects to the circuit board.
Pull the tape connection to disconnect the back LCD screen from the circuit board.
5 weitere Personen haben diese Anleitung absolviert.
