Zum Hauptinhalt wechseln
Samsung DV300F Lens Replacement
Was du brauchst
  1. Samsung DV300F Lens Replacement, Front and Rear Casing: Schritt 1, Bild 1 von 3 Samsung DV300F Lens Replacement, Front and Rear Casing: Schritt 1, Bild 2 von 3 Samsung DV300F Lens Replacement, Front and Rear Casing: Schritt 1, Bild 3 von 3
    • Remove the two black 4.2 mm screws on the right side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the left side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the bottom of the camera using a Phillips #0 screwdriver.
  2. Samsung DV300F Lens Replacement: Schritt 2, Bild 1 von 2 Samsung DV300F Lens Replacement: Schritt 2, Bild 2 von 2
    • Remove the back case of the camera carefully.
  3. Samsung DV300F Lens Replacement: Schritt 3, Bild 1 von 3 Samsung DV300F Lens Replacement: Schritt 3, Bild 2 von 3 Samsung DV300F Lens Replacement: Schritt 3, Bild 3 von 3
    • Remove the front case of the camera.
    • Remove the front LCD screen from the front case next to the lens.
  4. Samsung DV300F Lens Replacement, Back Button Control: Schritt 4, Bild 1 von 2 Samsung DV300F Lens Replacement, Back Button Control: Schritt 4, Bild 2 von 2
    • Remove the blue button control from its position next to the LCD screen.
    • Pull the ribbon cable to disconnect the blue button control from the camera.
  5. Samsung DV300F Lens Replacement, Back LCD Screen: Schritt 5, Bild 1 von 1
    • Remove the back LCD screen from its place carefully.
  6. Samsung DV300F Lens Replacement: Schritt 6, Bild 1 von 2 Samsung DV300F Lens Replacement: Schritt 6, Bild 2 von 2
    • Flip the black tab where the back LCD screen connects to the circuit board.
    • Pull the tape connection to disconnect the back LCD screen from the circuit board.
  7. Samsung DV300F Lens Replacement, Lens: Schritt 7, Bild 1 von 2 Samsung DV300F Lens Replacement, Lens: Schritt 7, Bild 2 von 2
    • Unscrew the 3 silver #0 Phillips 4.45mm screws from the circuit board cover
    • Remove the circuit board cover
  8. Samsung DV300F Lens Replacement: Schritt 8, Bild 1 von 2 Samsung DV300F Lens Replacement: Schritt 8, Bild 2 von 2
    • Flip the first black tab connecting the lens to the circuit board
    • Flip the second black tab connecting the lens to the circuit board
    • Push the lens out from the front to remove it from the camera
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
Baylor, Team 5-10, Williams Spring 2015 Mitglied von Baylor, Team 5-10, Williams Spring 2015
BU-WILLIAMS-S15S5G10
3 Mitglieder
10 Anleitungen geschrieben
1 Kommentar zur Anleitung
pourquoi ne pas aussi montrer comment demonter le lens de samsung dv300f
nouzalek - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 88
Insgesamt: 2,572
