Zum Hauptinhalt wechseln
Samsung DVD-HD850 Player Disk Tray Replacement
Was du brauchst
  1. Samsung DVD-HD850 Player Disk Tray Replacement, Locate and Remove The Disk Tray: Schritt 1, Bild 1 von 1
    • *NOTE* remember to never connect to power when working on electrical components
    • Find and locate the disk tray it is located top right hand side of the component when the back of the device ( dvd player ) is facing you.
  2. Samsung DVD-HD850 Player Disk Tray Replacement, Removing The Data Strips: Schritt 2, Bild 1 von 1
    • Locate and gently remove the data strips on the tray. There are three in total, two on the left hand side and one on the right.
  3. Samsung DVD-HD850 Player Disk Tray Replacement, Removing The Screws: Schritt 3, Bild 1 von 3 Samsung DVD-HD850 Player Disk Tray Replacement, Removing The Screws: Schritt 3, Bild 2 von 3 Samsung DVD-HD850 Player Disk Tray Replacement, Removing The Screws: Schritt 3, Bild 3 von 3
    • As noted by the red circles, locate and remove the screws one at a time
  4. Samsung DVD-HD850 Player Disk Tray Replacement, Disk Tray Removal: Schritt 4, Bild 1 von 1
    • After removing the clips slowly incline the disk drive towards you and unclip it from the two (2) brackets located on the top
    • Be careful not to push too much pressure on the brackets since they tend to break easily
  5. Samsung DVD-HD850 Player Disk Tray Replacement, Success!: Schritt 5, Bild 1 von 1
    • Congrats! You have sucessfully have taken out the disk drive
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Carlos
354 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 1-6, Duarte Fall 2014 Mitglied von UMass Dartmouth, Team 1-6, Duarte Fall 2014
UMASSD-DUARTE-F14S1G6
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 547
