Zum Hauptinhalt wechseln
Samsung DVD-HD850 Player Power Cord Replacement
Was du brauchst
  1. Samsung DVD-HD850 Player Power Cord Replacement, Cover: Schritt 1, Bild 1 von 1
    • with the front of the device facing you, turn the device 180 degrees so the back panel of the device is facing you
  2. Samsung DVD-HD850 Player Power Cord Replacement, Locate and remove screws: Schritt 2, Bild 1 von 1
    • locate the three (3) screws on the back panel of the device that are implanted in the device
    • to remove the screws, use the tool(s) listed above (right underneath the introduction) and twist the screws counter-clockwise to remove them from the device
  3. Samsung DVD-HD850 Player Power Cord Replacement, Remove Cover: Schritt 3, Bild 1 von 1
    • to remove the cover of the device, pull the cover towards the back of the device until it is completely removed so you can see the insides of the device
  4. Samsung DVD-HD850 Player Power Cord Replacement, Replacing the power cord: Schritt 4, Bild 1 von 2 Samsung DVD-HD850 Player Power Cord Replacement, Replacing the power cord: Schritt 4, Bild 2 von 2
    • Unclip the old power cord from the dual pin connector.
    • Once the old power cord has been unclipped take the new power cord and simply clip it in where the old one was.
  5. Samsung DVD-HD850 Player Power Cord Replacement, Adjust the wire: Schritt 5, Bild 1 von 2 Samsung DVD-HD850 Player Power Cord Replacement, Adjust the wire: Schritt 5, Bild 2 von 2
    • Adjust the rubber block on the power cord so that it fits in the slot on the back of the DVD player.
    • This makes it so that the cover panel will be able to slide back on.
Abschluss
Robert Moss
201 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 1-6, Duarte Fall 2014 Mitglied von UMass Dartmouth, Team 1-6, Duarte Fall 2014
UMASSD-DUARTE-F14S1G6
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 407
