Was du brauchst
Open the tray by pressing the eject button
Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
Press the eject button to insert the tray
After the tray is closed unplug DVD player
There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
Locate the white clip that attaches the cord to the motherboard
Grasp clip and squeeze to release
Lift up and remove power cord
Slide cord mount from outer case
Remove the power cord and first two ribbons by pulling them directly out of their sockets.
Unscrew the 2 screws on the motherboard
Unscrew the 2 screws on the back
Disconnect the wires and ribbon by pulling them out of their respective connections
The LCD screen has pins attaching it to the motherboard. Flip the motherboard over.
De-solder LCD screen pins from the motherboard.
Pinch black tabs to remove LCD screen from motherboard.
Solder the new LCD screen pins into motherboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
