Zum Hauptinhalt wechseln
Samsung DVD-P230 Tray Motor Replacement
Was du brauchst
  1. Samsung DVD-P230 Tray Motor Replacement, Outer Cover & Faceplate: Schritt 1, Bild 1 von 3 Samsung DVD-P230 Tray Motor Replacement, Outer Cover & Faceplate: Schritt 1, Bild 2 von 3 Samsung DVD-P230 Tray Motor Replacement, Outer Cover & Faceplate: Schritt 1, Bild 3 von 3
    • Open the tray by pressing the eject button
    • Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
  2. Samsung DVD-P230 Tray Motor Replacement: Schritt 2, Bild 1 von 1
    • Press the eject button to insert the tray
    • After the tray is closed unplug DVD player
  3. Samsung DVD-P230 Tray Motor Replacement: Schritt 3, Bild 1 von 1
    • Unscrew the 3 screws in the back.
  4. Samsung DVD-P230 Tray Motor Replacement: Schritt 4, Bild 1 von 2 Samsung DVD-P230 Tray Motor Replacement: Schritt 4, Bild 2 von 2
    • Pull the outer case upward and then towards you.
  5. Samsung DVD-P230 Tray Motor Replacement: Schritt 5, Bild 1 von 3 Samsung DVD-P230 Tray Motor Replacement: Schritt 5, Bild 2 von 3 Samsung DVD-P230 Tray Motor Replacement: Schritt 5, Bild 3 von 3
    • There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
  6. Samsung DVD-P230 Tray Motor Replacement: Schritt 6, Bild 1 von 2 Samsung DVD-P230 Tray Motor Replacement: Schritt 6, Bild 2 von 2
    • Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
  7. Samsung DVD-P230 Tray Motor Replacement, Power Cord: Schritt 7, Bild 1 von 3 Samsung DVD-P230 Tray Motor Replacement, Power Cord: Schritt 7, Bild 2 von 3 Samsung DVD-P230 Tray Motor Replacement, Power Cord: Schritt 7, Bild 3 von 3
    • Locate the white clip that attaches the cord to the motherboard
    • Grasp clip and squeeze to release
    • Lift up and remove power cord
    • Slide cord mount from outer case
  8. Samsung DVD-P230 Tray Motor Replacement, Tray: Schritt 8, Bild 1 von 3 Samsung DVD-P230 Tray Motor Replacement, Tray: Schritt 8, Bild 2 von 3 Samsung DVD-P230 Tray Motor Replacement, Tray: Schritt 8, Bild 3 von 3
    • Remove the three screws holding in the DVD tray
  9. Samsung DVD-P230 Tray Motor Replacement: Schritt 9, Bild 1 von 2 Samsung DVD-P230 Tray Motor Replacement: Schritt 9, Bild 2 von 2
    • Remove the power cord and first two ribbons by pulling them directly out of their sockets.
  10. Samsung DVD-P230 Tray Motor Replacement: Schritt 10, Bild 1 von 2 Samsung DVD-P230 Tray Motor Replacement: Schritt 10, Bild 2 von 2
    • Gently lift the DVD tray off of the motherboard.
  11. Samsung DVD-P230 Tray Motor Replacement, Tray Motor: Schritt 11, Bild 1 von 2 Samsung DVD-P230 Tray Motor Replacement, Tray Motor: Schritt 11, Bild 2 von 2
    • Spin the small gear shown to the right to begin opening the tray. There should be relatively little resistance in the gear.
  12. Samsung DVD-P230 Tray Motor Replacement: Schritt 12, Bild 1 von 3 Samsung DVD-P230 Tray Motor Replacement: Schritt 12, Bild 2 von 3 Samsung DVD-P230 Tray Motor Replacement: Schritt 12, Bild 3 von 3
    • Use your fingers to pull the shown tabs towards the sides of the tray, releasing the internal tray that contains the laser.
  13. Samsung DVD-P230 Tray Motor Replacement: Schritt 13, Bild 1 von 2 Samsung DVD-P230 Tray Motor Replacement: Schritt 13, Bild 2 von 2
    • In order to remove the tray motor you must detach the small rubber band that runs between the two shown wheels.
    • If the rubber band is improperly fitted onto one of the wheels or broken this is probably the cause of the tray not opening or closing.
  14. Samsung DVD-P230 Tray Motor Replacement: Schritt 14, Bild 1 von 2 Samsung DVD-P230 Tray Motor Replacement: Schritt 14, Bild 2 von 2
    • Flip over the tray.
    • Unscrew the two screws that attach the motor to the tray.
    • Once completed the motor can be easily removed and replaced.
Abschluss
Mitchell Hart
903 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 3-30, Regan Winter 2011 Mitglied von Cal Poly, Team 3-30, Regan Winter 2011
CPSU-REGAN-W11S3G30
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 5,023
