Zum Hauptinhalt wechseln
Samsung Droid Charge Screen Replacement
Was du brauchst
  1. Samsung Droid Charge Screen Replacement, Rear Cover: Schritt 1, Bild 1 von 1
    • Open up the back case on the phone from the groove in the bottom of the phone.
    • You can do this by inserting a fingernail or similarly thin object into the groove and pulling up with mild force.
  2. Samsung Droid Charge Screen Replacement, Battery: Schritt 2, Bild 1 von 1
    • Below the left part of the bottom of the battery area there will be a groove large enough to fit in a finger or screw driver head.
    • Use the groove to lever out the battery gently, in order to not damage either the battery or phone. Store the battery in a safe place.
  3. Samsung Droid Charge Screen Replacement, microSD: Schritt 3, Bild 1 von 1
    • Push the SD card further into its metal slot until you hear a click.
    • Release the card, and it should automatically eject itself.
    • Remove the SD card.
  4. Samsung Droid Charge Screen Replacement, SIM Card: Schritt 4, Bild 1 von 1
    • Slide the SIM card out of its casing by pushing on it and sliding it upward.
  5. Samsung Droid Charge Screen Replacement, Screen: Schritt 5, Bild 1 von 1
    • Locate the 7 small black screws located around the edge of the phone under the battery cover.
    • With a small Philips head screwdriver, remove each of the screws and place them in a secure location.
  6. Samsung Droid Charge Screen Replacement: Schritt 6, Bild 1 von 1
    • Locate your pry tool.
    • Insert the pry tool into the plastic edge that runs along the sides of the phone. Doing so will allow you to remove part of the back casing.
    • Use a prying motion to lift the casing up.
    • Repeat this motion all around the screen edge until the casing pops off.
  7. Samsung Droid Charge Screen Replacement: Schritt 7, Bild 1 von 1
    • Release the one pop connector for the motherboard located on the right.
    • Release the volume button flex cable on the right.
    • Release the power button flex cable on the right.
    • Now the motherboard can be removed. Simply lift out the motherboard and set aside.
  8. Samsung Droid Charge Screen Replacement: Schritt 8, Bild 1 von 3 Samsung Droid Charge Screen Replacement: Schritt 8, Bild 2 von 3 Samsung Droid Charge Screen Replacement: Schritt 8, Bild 3 von 3
    • Using a hairdryer or heat gun, warm the phone. Doing so will warm the adhesive holding the screen in place, allowing us to continue disassembling the device.
    • Use the pry tool to pry the screen off the casing. You may need to use force to overcome the adhesive.
    • Work carefully to prevent damage to the phone.
  9. Samsung Droid Charge Screen Replacement: Schritt 9, Bild 1 von 1
    • You can now swap out the old screen for your new one.
Ziellinie
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Luke Gordon
178 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 15-44, Forte Fall 2012 Mitglied von Cal Poly, Team 15-44, Forte Fall 2012
CPSU-FORTE-F12S15G44
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 2,987
