Zum Hauptinhalt wechseln
Einleitung
Use this guide to replace your front panel assembly.
  1. Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack. Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
    • Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack.
    • Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
  2. Lift and remove the rear case. Lift and remove the rear case.
    • Lift and remove the rear case.
  3. Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click. After the click, release the card and it will pop out of its slot.
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • During reassembly, push the microSD card into the slot until it clicks in place.
  4. Pull the microSD card away from its slot.
    • Pull the microSD card away from its slot.
  5. Wedge a plastic opening tool into the crevice between the battery and midframe located near the bottom left corner. Push the plastic opening tool downward to pry the battery up from its housing.
    • Wedge a plastic opening tool into the crevice between the battery and midframe located near the bottom left corner.
    • Push the plastic opening tool downward to pry the battery up from its housing.
  6. Lift and remove the battery from the midframe. Lift and remove the battery from the midframe.
    • Lift and remove the battery from the midframe.
  7. Remove the six 4.0 mm Phillips #00 screws securing the midframe to the front panel assembly.
    • Remove the six 4.0 mm Phillips #00 screws securing the midframe to the front panel assembly.
  8. Unless you pry at the right insertion points, you might have a difficult time removing the midframe. This shot of the display assembly, with display glass facing down, is meant to help you locate them. The first insertion point is a divot to the left of the micro-USB port.
    • Unless you pry at the right insertion points, you might have a difficult time removing the midframe. This shot of the display assembly, with display glass facing down, is meant to help you locate them.
    • The first insertion point is a divot to the left of the micro-USB port.
    • The second insertion point is a divot to the right of the micro-USB port near the corner of the phone.
    • The final insertion point is located about two inches to the right of the volume control toggle, toward the corner of the phone. An additional insertion point is located slightly to the right of the volume button if you need it.
  9. Insert a plastic opening tool slightly to the left of the micro-USB port, and pry between the midframe and the display to open a gap. Insert a plastic opening tool slightly to the left of the micro-USB port, and pry between the midframe and the display to open a gap.
    • Insert a plastic opening tool slightly to the left of the micro-USB port, and pry between the midframe and the display to open a gap.
  10. Wedge a plastic opening tool slightly to the right of the micro-USB port, and pry between the midframe and the display to widen the gap. Wedge a plastic opening tool slightly to the right of the micro-USB port, and pry between the midframe and the display to widen the gap.
    • Wedge a plastic opening tool slightly to the right of the micro-USB port, and pry between the midframe and the display to widen the gap.
  11. Pry again about two inches to the right of the volume control toggles between the midframe and the front panel assembly. Pry again about two inches to the right of the volume control toggles between the midframe and the front panel assembly.
    • Pry again about two inches to the right of the volume control toggles between the midframe and the front panel assembly.
  12. Pull the micro-USB end of the front panel assembly out and away from the midframe and lift up to free it entirely. Pull the micro-USB end of the front panel assembly out and away from the midframe and lift up to free it entirely.
    • Pull the micro-USB end of the front panel assembly out and away from the midframe and lift up to free it entirely.
  13. Headphone jack/vibrator assembly cable connector
    • Headphone jack/vibrator assembly cable connector
    • Front-facing camera cable connector
    • Digitizer cable connector
    • Display cable connector
  14. Use the flat end of a spudger to disconnect the headphone jack/vibrator assembly cable. Use the flat end of a spudger to disconnect the headphone jack/vibrator assembly cable.
    • Use the flat end of a spudger to disconnect the headphone jack/vibrator assembly cable.
  15. Use the flat end of a spudger to disconnect the front-facing camera cable connector. Use the flat end of a spudger to disconnect the front-facing camera cable connector.
    • Use the flat end of a spudger to disconnect the front-facing camera cable connector.
  16. Carefully disconnect the digitizer display cable.
    • Carefully disconnect the digitizer display cable.
  17. Use a spudger to disconnect the display cable connector.
    • Use a spudger to disconnect the display cable connector.
  18. Remove the two 3 mm Phillips #00 screws.
    • Remove the two 3 mm Phillips #00 screws.
  19. Lift the micro-USB end of the motherboard away from the display assembly and pull it down. Be mindful that you don't snag the motherboard on any cables as you remove it. Be mindful that you don't snag the motherboard on any cables as you remove it.
    • Lift the micro-USB end of the motherboard away from the display assembly and pull it down.
    • Be mindful that you don't snag the motherboard on any cables as you remove it.
  20. The microphone cover fits in a notch and over a small peg in the display assembly, ensure it is well seated before sealing your device. Make sure the microphone cover stays in its slot on the display assembly.
    • The microphone cover fits in a notch and over a small peg in the display assembly, ensure it is well seated before sealing your device.
    • Make sure the microphone cover stays in its slot on the display assembly.
    • When you removed the motherboard, the microphone cover may have remained stuck on the microphone. Put it back in its notch in the display assembly to avoid losing it.
  21. Remove the 2.3 mm Phillips #00 screw securing the front-facing camera bracket to the display assembly.
    • Remove the 2.3 mm Phillips #00 screw securing the front-facing camera bracket to the display assembly.
  22. Remove the front-facing camera bracket from the display assembly.
    • Remove the front-facing camera bracket from the display assembly.
  23. Using a pair of tweezers, or your fingers, remove the front-facing camera/earpiece speaker assembly. Using a pair of tweezers, or your fingers, remove the front-facing camera/earpiece speaker assembly.
    • Using a pair of tweezers, or your fingers, remove the front-facing camera/earpiece speaker assembly.
  24. Insert the pointed end of a spudger into the gap in the corner of the midframe to free the vibrator from the adhesive. Do not completely remove the vibrator, it is still attached to the headphone jack/vibrator assembly and can only come out with the rest of the unit.
    • Insert the pointed end of a spudger into the gap in the corner of the midframe to free the vibrator from the adhesive.
    • Do not completely remove the vibrator, it is still attached to the headphone jack/vibrator assembly and can only come out with the rest of the unit.
  25. Use the flat end of a spudger to release the headphone jack from the adhesive securing it to the midframe.
    • Use the flat end of a spudger to release the headphone jack from the adhesive securing it to the midframe.
  26. Remove the headphone jack/vibrator assembly from the display assembly.
    • Remove the headphone jack/vibrator assembly from the display assembly.
  27. Front panel assembly remains.
    • Front panel assembly remains.
Abschluss
17 weitere Nutzer haben diese Anleitung absolviert.
Sam Goldheart
439.485 Reputation
547 Anleitungen geschrieben
iFixit Mitglied von iFixit
Community
137 Mitglieder
16.428 Anleitungen geschrieben
My display is broken but the touch screen still works. How do you replace the display?
atworktom - Antwort
I attempted to replace the display glass alone on a Virgin Mobile Galaxy SII, and was unsuccessful. Removing the Glass from the Digitizer proved to be extremely difficult. It seems as if the Virgin Mobile version of the SII is not meant for repair, so easily.
Edward Weissbard - Antwort
I always see it see my good guide how do i fix wireless displays connections in windows 10. I am sure you will get many of clue here.
sam karol - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 3
Insgesamt: 19,138
