Zum Hauptinhalt wechseln
Samsung Epic 4G Touch microSD Card Replacement
Was du brauchst
  1. Samsung Epic 4G Touch microSD Card Replacement, Rear Case: Schritt 1, Bild 1 von 2 Samsung Epic 4G Touch microSD Card Replacement, Rear Case: Schritt 1, Bild 2 von 2
    • Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack.
    • Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
  2. Samsung Epic 4G Touch microSD Card Replacement: Schritt 2, Bild 1 von 2 Samsung Epic 4G Touch microSD Card Replacement: Schritt 2, Bild 2 von 2
    • Lift and remove the rear case.
  3. Samsung Epic 4G Touch microSD Card Replacement, microSD Card: Schritt 3, Bild 1 von 2 Samsung Epic 4G Touch microSD Card Replacement, microSD Card: Schritt 3, Bild 2 von 2
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • During reassembly, push the microSD card into the slot until it clicks in place.
  4. Samsung Epic 4G Touch microSD Card Replacement: Schritt 4, Bild 1 von 1
    • Pull the microSD card away from its slot.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Uhh.... my Australian SGSII looks different to this...
Bonj - Antwort
If you are having trouble addint a 64gb micro sd card, it's because you have to first format that card to FAT32. You have to do that to the memory card through a computer. Youtube too, it'll help
asff - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 17
Insgesamt: 4,372
