Einleitung
You will need to find a clean area to work in and have the necessary tools. Follow this guide to gain access to your cellphone's antenna/speaker module.
Was du brauchst
Use a nylon spudger to gently pry the silver plastic back plate from the body of the phone.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Pop the antenna plug off of its socket with a pair of metal tweezers.
Pry the antenna/speaker component out of its casing. You need to use a little force to get the piece to pop out.
2 weitere Personen haben diese Anleitung absolviert.
