Einleitung
You will need to find a clean area to work in and have the necessary tools. Follow this guide to gain access to your cellphone's digitizer and screen.
Was du brauchst
Continuing to use the Phillips #00 screwdriver, gently pry the silver plastic back plate from the body of the phone.
Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
Slightly pull up one side of the motherboard.
Pull the button/microphone plug out of its socket.
Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
Flip phone over so you are looking at the front screen of the phone. (The back is already taken off and parts removed)
Use a small tool to pry the digitizer and screen (together) from the frame of the phone. This may take some time and careful work because it is glued down to the frame.
Next, carefully pull the digitizer away from the screen.
At this point you can replace either the screen or the digitizer.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
Do these steps also work for the Samsung Eternity 2?
Está mierda no sale
