Einleitung
You will need to find a clean area to work in and have the necessary tools. Follow this guide to gain access to your cellphone's input jack module.
Was du brauchst
Continuing to use the Phillips #00 screwdriver, gently pry the silver plastic back plate from the body of the phone.
Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
