Zum Hauptinhalt wechseln
Samsung Eternity Motherboard Replacement
Was du brauchst
    • Remove the back battery cover.
  1. Samsung Eternity Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Using the Phillips #00 screwdriver, remove the phone's battery.
  2. Samsung Eternity Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver
  3. Samsung Eternity Motherboard Replacement: Schritt 4, Bild 1 von 2 Samsung Eternity Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Continuing to use the Phillips #00 screwdriver, gently pry the silver plastic back plate from the body of the phone.
  4. Samsung Eternity Motherboard Replacement, Motherboard: Schritt 5, Bild 1 von 1
    • It is very easy to rip motherboard cables and damage fragile motherboard clips. Be careful when you are removing every component.
    • Pull the antenna plug out of its socket.
  5. Samsung Eternity Motherboard Replacement: Schritt 6, Bild 1 von 3 Samsung Eternity Motherboard Replacement: Schritt 6, Bild 2 von 3 Samsung Eternity Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
  6. Samsung Eternity Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Pop the red hinged-release lever away from its ribbon. Then pull it out.
  7. Samsung Eternity Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Peel the button sensor on the side of the motherboard off of the case.
  8. Samsung Eternity Motherboard Replacement: Schritt 9, Bild 1 von 3 Samsung Eternity Motherboard Replacement: Schritt 9, Bild 2 von 3 Samsung Eternity Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Slightly pull up one side of the motherboard.
    • Pull the button/microphone plug out of its socket.
    • Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
  9. Samsung Eternity Motherboard Replacement: Schritt 10, Bild 1 von 1
    • You have successfully removed the motherboard from the phone.
Abschluss
Cal Poly, Team 15-11, Regan Spring 2011 Mitglied von Cal Poly, Team 15-11, Regan Spring 2011
CPSU-REGAN-S11S15G11
5 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 2,304
