Zum Hauptinhalt wechseln
Samsung Exhibit II 4G Display Assembly Replacement
Was du brauchst
  1. Samsung Exhibit II 4G Display Assembly Replacement, Battery: Schritt 1, Bild 1 von 1
    • Insert plastic opening tool under back cover.
    • Apply pressure on tool while using a downward motion to pop off back cover.
  2. Samsung Exhibit II 4G Display Assembly Replacement: Schritt 2, Bild 1 von 1
    • Insert plastic opening tool under battery.
    • Pry battery out.
  3. Samsung Exhibit II 4G Display Assembly Replacement, Top Rear Housing Cover: Schritt 3, Bild 1 von 1
    • Pry the top cover upward to remove it from the phone.
  4. Samsung Exhibit II 4G Display Assembly Replacement: Schritt 4, Bild 1 von 1
    • Remove the top cover.
  5. Samsung Exhibit II 4G Display Assembly Replacement: Schritt 5, Bild 1 von 2 Samsung Exhibit II 4G Display Assembly Replacement: Schritt 5, Bild 2 von 2
    • Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
    • Two screws from top and two screws from back.
  6. Samsung Exhibit II 4G Display Assembly Replacement: Schritt 6, Bild 1 von 3 Samsung Exhibit II 4G Display Assembly Replacement: Schritt 6, Bild 2 von 3 Samsung Exhibit II 4G Display Assembly Replacement: Schritt 6, Bild 3 von 3
    • Insert plastic opening tool under top cover.
    • Using hand slide top cover away from phone.
  7. Samsung Exhibit II 4G Display Assembly Replacement, Midframe: Schritt 7, Bild 1 von 1
    • Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
  8. Samsung Exhibit II 4G Display Assembly Replacement: Schritt 8, Bild 1 von 1
    • Insert plastic opening tool between back assembly and phone.
    • Pry the back assembly away from phone.
  9. Samsung Exhibit II 4G Display Assembly Replacement: Schritt 9, Bild 1 von 1
    • With plastic opening tool continue prying around the edge of the back assembly.
  10. Samsung Exhibit II 4G Display Assembly Replacement: Schritt 10, Bild 1 von 1
    • Pull back panel assembly away from main body.
  11. Samsung Exhibit II 4G Display Assembly Replacement, Vibration Motor: Schritt 11, Bild 1 von 2 Samsung Exhibit II 4G Display Assembly Replacement, Vibration Motor: Schritt 11, Bild 2 von 2
    • Insert the pointed end of a spudger into the gap in the round housing frame.
    • Using spudger to remove vibrator remove from the adhesive.
  12. Samsung Exhibit II 4G Display Assembly Replacement: Schritt 12, Bild 1 von 2 Samsung Exhibit II 4G Display Assembly Replacement: Schritt 12, Bild 2 von 2
    • Use the flat end of a spudger to remove vibrator cable from motherboard.
  13. Samsung Exhibit II 4G Display Assembly Replacement, Rear Facing Camera: Schritt 13, Bild 1 von 1
    • Use the flat end of a spudger to disconnect the camera assembly cable.
  14. Samsung Exhibit II 4G Display Assembly Replacement: Schritt 14, Bild 1 von 2 Samsung Exhibit II 4G Display Assembly Replacement: Schritt 14, Bild 2 von 2
    • Remove camera from square housing.
  15. Samsung Exhibit II 4G Display Assembly Replacement, Motherboard: Schritt 15, Bild 1 von 3 Samsung Exhibit II 4G Display Assembly Replacement, Motherboard: Schritt 15, Bild 2 von 3 Samsung Exhibit II 4G Display Assembly Replacement, Motherboard: Schritt 15, Bild 3 von 3
    • Insert the spudger under each corner ribbon cable and lift them out of the way.
    • Use care when lifting the ribbon cables.
    • Insert a plastic pry tool into the gap between motherboard and base of phone
  16. Samsung Exhibit II 4G Display Assembly Replacement: Schritt 16, Bild 1 von 3 Samsung Exhibit II 4G Display Assembly Replacement: Schritt 16, Bild 2 von 3 Samsung Exhibit II 4G Display Assembly Replacement: Schritt 16, Bild 3 von 3
    • Tilt the motherboard up carefully.
    • Be sure not to damage the ribbon cable still connected at the bottom of the motherboard.
    • Use a spudger to pry the connector from the socket on the motherboard.
    • Lift motherboard from frame.
  17. Samsung Exhibit II 4G Display Assembly Replacement, Headphone Jack: Schritt 17, Bild 1 von 3 Samsung Exhibit II 4G Display Assembly Replacement, Headphone Jack: Schritt 17, Bild 2 von 3 Samsung Exhibit II 4G Display Assembly Replacement, Headphone Jack: Schritt 17, Bild 3 von 3
    • Insert flat end of spudger between support panel and front assembly.
    • Using a spudger pry up to create opening to insert plastic opening tool.
  18. Samsung Exhibit II 4G Display Assembly Replacement: Schritt 18, Bild 1 von 2 Samsung Exhibit II 4G Display Assembly Replacement: Schritt 18, Bild 2 von 2
    • Insert a plactic opening tool in opening.
    • Use plastic opening tool to pry around the edge of support panel to free it from front assembly.
  19. Samsung Exhibit II 4G Display Assembly Replacement: Schritt 19, Bild 1 von 3 Samsung Exhibit II 4G Display Assembly Replacement: Schritt 19, Bild 2 von 3 Samsung Exhibit II 4G Display Assembly Replacement: Schritt 19, Bild 3 von 3
    • Insert the pointed end of a spudger into gap.
    • Lift spudger away from support plate to remove headphone component.
  20. Samsung Exhibit II 4G Display Assembly Replacement: Schritt 20, Bild 1 von 3 Samsung Exhibit II 4G Display Assembly Replacement: Schritt 20, Bild 2 von 3 Samsung Exhibit II 4G Display Assembly Replacement: Schritt 20, Bild 3 von 3
    • Use the flat end of the spudger to remove headphone jack component from rectangular housing.
  21. Samsung Exhibit II 4G Display Assembly Replacement, Display Assembly: Schritt 21, Bild 1 von 3 Samsung Exhibit II 4G Display Assembly Replacement, Display Assembly: Schritt 21, Bild 2 von 3 Samsung Exhibit II 4G Display Assembly Replacement, Display Assembly: Schritt 21, Bild 3 von 3
    • The the flat end of a spudger between componet and frame.
    • Use the the spudger to lift the componet from the frame.
  22. Samsung Exhibit II 4G Display Assembly Replacement: Schritt 22, Bild 1 von 3 Samsung Exhibit II 4G Display Assembly Replacement: Schritt 22, Bild 2 von 3 Samsung Exhibit II 4G Display Assembly Replacement: Schritt 22, Bild 3 von 3
    • Insert the spudger between blue flim and the back of the LCD.
    • Using the spudger lift blue film away from LCD.
  23. Samsung Exhibit II 4G Display Assembly Replacement: Schritt 23, Bild 1 von 3 Samsung Exhibit II 4G Display Assembly Replacement: Schritt 23, Bild 2 von 3 Samsung Exhibit II 4G Display Assembly Replacement: Schritt 23, Bild 3 von 3
    • Notice ribbon cable slides under the tan square component.
  24. Samsung Exhibit II 4G Display Assembly Replacement: Schritt 24, Bild 1 von 3 Samsung Exhibit II 4G Display Assembly Replacement: Schritt 24, Bild 2 von 3 Samsung Exhibit II 4G Display Assembly Replacement: Schritt 24, Bild 3 von 3
    • Insert a plastic opening tool between LCD and Digitizer screen.
    • Use plastic opening tool to pry and lift the LCD from the glass screen.
    • Adhesive material around edge of LCD.
  25. Samsung Exhibit II 4G Display Assembly Replacement: Schritt 25, Bild 1 von 2 Samsung Exhibit II 4G Display Assembly Replacement: Schritt 25, Bild 2 von 2
    • Lift LCD away from digitizer screen.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
David R
1.152 Reputation
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 757
