Was du brauchst
Close the phone and flip it on it's back.
Under the SAMSUNG logo there will be a bit of space to open the phone with your fingernail or a tool.
Finally, pull the cover slowly and carefully so it doesn't break.
Put your finger on the space highlighted in red, and press while slowly lifting the old battery.
Next insert the new battery by following the steps above backwards and making sure the SAMSUNG logo is on the top and the pins of the phone align with the contacts of the battery correctly.
The only thing left to do is to put the cover back and press it slightly.
To reassemble your device, put the cover back.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
