Einleitung
Samsung A10, A10s Micro USB Charging connector Replacement
Einführungsvideo
Remove the SIM Tray.
Use plastic tools to separate the back cover.
Remove the silver Phillips screws to be able to disassemble the motherboard shields.
Disconnect the Main flex cable and the coaxial antenna cables and remove the charging board.
Cover the microphone hole to prevent microphone damage.
Use hot air to remove the Micro USB connector.
11 weitere Nutzer:innen haben diese Anleitung absolviert.
