Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Use this guide to replace the daughterboard containing the charge port and headphone jack.
  1. Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole in the SIM card tray. Press to eject the tray.
    • Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole in the SIM card tray.
    • Press to eject the tray.
  2. Remove the SIM card tray from the phone. The SIM card(s) and SD card will fall out of the tray easily.
    • Remove the SIM card tray from the phone.
    • The SIM card(s) and SD card will fall out of the tray easily.
    • When reinserting the tray, ensure the SIM card and SD card are in the correct slots and oriented correctly.
    • For dual-SIM versions of this phone, there may be two SIM cards. Ensure the SIM cards are placed in the slots corresponding to the correct phone lines.
  3. The back cover is held in place by plastic clips.
    • The back cover is held in place by plastic clips.
    • Insert an opening pick between the screen and the back cover on the bottom of the phone where the charging port is located.
  4. Slide the opening pick to the bottom left corner to release the clips.
    • Slide the opening pick to the bottom left corner to release the clips.
  5. Slide the opening pick along the left edge to the top left corner of the phone, to release the clips.
    • Slide the opening pick along the left edge to the top left corner of the phone, to release the clips.
  6. Slide the opening pick from the top left corner to the top right corner to release the plastic clips.
    • Slide the opening pick from the top left corner to the top right corner to release the plastic clips.
  7. Slide the opening pick from the top right corner to the bottom right corner to release the remaining clips.
    • Slide the opening pick from the top right corner to the bottom right corner to release the remaining clips.
  8. Das Essential Toolkit
    Die nützlichsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  9. Remove the back cover.
    • Remove the back cover.
  10. Remove screws from the motherboard antenna cover.
    • Remove screws from the motherboard antenna cover.
    • 3 Phillips #00, 3mm length.
  11. Use the tip of a spudger or tweezers to remove the antenna cover.
    • Use the tip of a spudger or tweezers to remove the antenna cover.
  12. Remove screws from the motherboard cover.
    • Remove screws from the motherboard cover.
  13. Use the tip of a spudger or tweezers to remove the motherboard cover.
    • Use the tip of a spudger or tweezers to remove the motherboard cover.
  14. Use a spudger to disconnect the battery by prying the connector straight up from its socket. Use a spudger to disconnect the battery by prying the connector straight up from its socket.
    • Use a spudger to disconnect the battery by prying the connector straight up from its socket.
  15. Gently flex the battery connector away from its socket.
    • Gently flex the battery connector away from its socket.
  16. Remove screws from daughterboard cover.
    • Remove screws from daughterboard cover.
    • 7 Phillips #00, 3mm length.
  17. There is a plastic tab securing the top left corner of the daughterboard cover. Use a pair of tweezers to lift up the bottom of the daughterboard cover to a ~30 degree angle.
    • There is a plastic tab securing the top left corner of the daughterboard cover.
    • Use a pair of tweezers to lift up the bottom of the daughterboard cover to a ~30 degree angle.
    • Pull the daughterboard cover straight out, away from the phone.
  18. Insert the flat end of a spudger under the interconnect flex connector, and gently pry it straight up. Insert the flat end of a spudger under the interconnect flex connector, and gently pry it straight up.
    • Insert the flat end of a spudger under the interconnect flex connector, and gently pry it straight up.
  19. Using a pair of tweezers, gently disconnect one of the antenna connectors. Using a pair of tweezers, gently disconnect one of the antenna connectors.
    • Using a pair of tweezers, gently disconnect one of the antenna connectors.
  20. Using a pair of tweezers, gently disconnect the other antenna connector.
    • Using a pair of tweezers, gently disconnect the other antenna connector.
  21. Remove screw from daughterboard.
    • Remove screw from daughterboard.
    • 1 Phillips #00, 2mm length.
  22. Remove the daughterboard.
    • Remove the daughterboard.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Thomas Boland
667 Reputation
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 13
Letzten 30 Tage: 57
Insgesamt: 264
