Zum Hauptinhalt wechseln
Samsung Galaxy A10e Motherboard Cover Replacement
Was du brauchst
  1. Samsung Galaxy A10e Motherboard Cover Replacement, SIM Card: Schritt 1, Bild 1 von 2 Samsung Galaxy A10e Motherboard Cover Replacement, SIM Card: Schritt 1, Bild 2 von 2
    • Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole in the SIM card tray.
    • Press to eject the tray.
  2. Samsung Galaxy A10e Motherboard Cover Replacement: Schritt 2, Bild 1 von 2 Samsung Galaxy A10e Motherboard Cover Replacement: Schritt 2, Bild 2 von 2
    • Remove the SIM card tray from the phone.
    • The SIM card(s) and SD card will fall out of the tray easily.
    • When reinserting the tray, ensure the SIM card and SD card are in the correct slots and oriented correctly.
    • For dual-SIM versions of this phone, there may be two SIM cards. Ensure the SIM cards are placed in the slots corresponding to the correct phone lines.
  3. Samsung Galaxy A10e Motherboard Cover Replacement, Back Cover: Schritt 3, Bild 1 von 1
    • The back cover is held in place by plastic clips.
    • Insert an opening pick between the screen and the back cover on the bottom of the phone where the charging port is located.
  4. Samsung Galaxy A10e Motherboard Cover Replacement: Schritt 4, Bild 1 von 1
    • Slide the opening pick to the bottom left corner to release the clips.
  5. Samsung Galaxy A10e Motherboard Cover Replacement: Schritt 5, Bild 1 von 1
    • Slide the opening pick along the left edge to the top left corner of the phone, to release the clips.
  6. Samsung Galaxy A10e Motherboard Cover Replacement: Schritt 6, Bild 1 von 1
    • Slide the opening pick from the top left corner to the top right corner to release the plastic clips.
  7. Samsung Galaxy A10e Motherboard Cover Replacement: Schritt 7, Bild 1 von 1
    • Slide the opening pick from the top right corner to the bottom right corner to release the remaining clips.
  8. Samsung Galaxy A10e Motherboard Cover Replacement: Schritt 8, Bild 1 von 1
    • Remove the back cover.
  9. Samsung Galaxy A10e Motherboard Cover Replacement, Motherboard Cover: Schritt 9, Bild 1 von 1
    • Remove screws from the motherboard antenna cover.
    • 3 Phillips #00, 3mm length.
  10. Samsung Galaxy A10e Motherboard Cover Replacement: Schritt 10, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Use the tip of a spudger or tweezers to remove the antenna cover.
  11. Samsung Galaxy A10e Motherboard Cover Replacement: Schritt 11, Bild 1 von 1
    • Remove screws from the motherboard cover.
  12. Samsung Galaxy A10e Motherboard Cover Replacement: Schritt 12, Bild 1 von 1
    • Use the tip of a spudger or tweezers to remove the motherboard cover.
Abschluss
8 weitere Personen haben diese Anleitung absolviert.
Thomas Boland
1.902 Reputation
5 Anleitungen geschrieben
1 Kommentar zur Anleitung
I have looked literally everywhere and nobody is covering the top motherboard 2 connectors w/ Ribbons on top the black squares one camera and the 1 to the right how does that 1 to the right connect with the ribbon please help thank you
amandacrockett385 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 71
Insgesamt: 2,551
