Zum Hauptinhalt wechseln
Samsung Galaxy A10e SIM Card Replacement
Was du brauchst
    1. Samsung Galaxy A10e SIM Card Replacement, SIM Card: Schritt 1, Bild 1 von 2 Samsung Galaxy A10e SIM Card Replacement, SIM Card: Schritt 1, Bild 2 von 2
      • Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole in the SIM card tray.
      • Press to eject the tray.
      Frag FixBot
      Kommentar hinzufügen
    2. Samsung Galaxy A10e SIM Card Replacement: Schritt 2, Bild 1 von 2 Samsung Galaxy A10e SIM Card Replacement: Schritt 2, Bild 2 von 2
      • Remove the SIM card tray from the phone.
      • The SIM card(s) and SD card will fall out of the tray easily.
      • When reinserting the tray, ensure the SIM card and SD card are in the correct slots and oriented correctly.
      • For dual-SIM versions of this phone, there may be two SIM cards. Ensure the SIM cards are placed in the slots corresponding to the correct phone lines.
      Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
3 Kommentare zur Anleitung
Access n control
Ken Cannon - Antwort Teilen
sam A 10 e ican not use sim card it says network is lockd how can i fix it
yz Nure - Antwort Teilen
SD card doesn't show.
How do I fix this?
David Isaac - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 13
Letzte 30 Tage: 56
Insgesamt: 2,309
