Zum Hauptinhalt wechseln
Samsung Galaxy A11 Vibration Motor Replacement
Was du brauchst
  1. Samsung Galaxy A11 Vibration Motor Replacement, Back Cover: Schritt 1, Bild 1 von 3 Samsung Galaxy A11 Vibration Motor Replacement, Back Cover: Schritt 1, Bild 2 von 3 Samsung Galaxy A11 Vibration Motor Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Place the SIM eject tool in the hole of the sim tray.
    • Push until part of the SIM tray is pushed out.
    • Pull out the rest of the SIM tray.
    Frag FixBot
    Kommentar hinzufügen
  2. Samsung Galaxy A11 Vibration Motor Replacement: Schritt 2, Bild 1 von 3 Samsung Galaxy A11 Vibration Motor Replacement: Schritt 2, Bild 2 von 3 Samsung Galaxy A11 Vibration Motor Replacement: Schritt 2, Bild 3 von 3
    • Gently pry open the area of the back cover near the SIM tray using an iFixit opening pick.
    • Gently move the pick along the gap and pry open the clips holding it together.
    • If possible, use multiple picks to prevent the back cover from closing.
    Frag FixBot
  3. Samsung Galaxy A11 Vibration Motor Replacement: Schritt 3, Bild 1 von 3 Samsung Galaxy A11 Vibration Motor Replacement: Schritt 3, Bild 2 von 3 Samsung Galaxy A11 Vibration Motor Replacement: Schritt 3, Bild 3 von 3
    • Using a hair dryer on low heat, heat the fingerprint sensor in increments of 30 seconds to loosen the surrounding adhesive.
    • Gently push the fingerprint sensor until it detaches from the back cover.
    • If needed, remove the button by prying it from the bottom of the device.
    Frag FixBot
  4. Samsung Galaxy A11 Vibration Motor Replacement, Battery: Schritt 4, Bild 1 von 3 Samsung Galaxy A11 Vibration Motor Replacement, Battery: Schritt 4, Bild 2 von 3 Samsung Galaxy A11 Vibration Motor Replacement, Battery: Schritt 4, Bild 3 von 3
    • Remove the three 3 mm screws from the shield using a Phillips #000 screwdriver.
    • Remove the shield from the phone.
    Frag FixBot
  5. Samsung Galaxy A11 Vibration Motor Replacement: Schritt 5, Bild 1 von 3 Samsung Galaxy A11 Vibration Motor Replacement: Schritt 5, Bild 2 von 3 Samsung Galaxy A11 Vibration Motor Replacement: Schritt 5, Bild 3 von 3
    • Using tweezers, a spudger, or your fingers, disconnect the battery press connector from the phone.
    Frag FixBot
  6. Samsung Galaxy A11 Vibration Motor Replacement: Schritt 6, Bild 1 von 3 Samsung Galaxy A11 Vibration Motor Replacement: Schritt 6, Bild 2 von 3 Samsung Galaxy A11 Vibration Motor Replacement: Schritt 6, Bild 3 von 3
    • If needed, use a hairdryer on low heat to soften the adhesive under the battery. If The Battery Is Expanded, DO NOT USE A HAIRDRYER or heat; be very careful when removing to not puncture the battery.
    • Use an iFixit pry tool to dig under the battery edge.
    • If needed, use multiple pry tools to hold the battery in place.
    • Continue to cut the adhesive under the battery until you are able to pry the battery away from the phone.
    • Remove the battery from the phone.
    Frag FixBot
  7. Samsung Galaxy A11 Vibration Motor Replacement, Daughterboard: Schritt 7, Bild 1 von 3 Samsung Galaxy A11 Vibration Motor Replacement, Daughterboard: Schritt 7, Bild 2 von 3 Samsung Galaxy A11 Vibration Motor Replacement, Daughterboard: Schritt 7, Bild 3 von 3
    • Remove the eight silver and black 3 mm screws from the speaker cover using a Phillips #000 screwdriver.
    • Remove the speaker cover from the device.
    Frag FixBot
  8. Samsung Galaxy A11 Vibration Motor Replacement: Schritt 8, Bild 1 von 3 Samsung Galaxy A11 Vibration Motor Replacement: Schritt 8, Bild 2 von 3 Samsung Galaxy A11 Vibration Motor Replacement: Schritt 8, Bild 3 von 3
    • Using a spudger, disconnect the antenna heads from the daughterboard.
    • Disconnect the ribbon cable from the daughterboard.
    Frag FixBot
  9. Samsung Galaxy A11 Vibration Motor Replacement: Schritt 9, Bild 1 von 3 Samsung Galaxy A11 Vibration Motor Replacement: Schritt 9, Bild 2 von 3 Samsung Galaxy A11 Vibration Motor Replacement: Schritt 9, Bild 3 von 3
    • Using tweezers, gently pry the daughterboard from the device.
    • When using metal tools, it is important to be gentle in order to not damage the device.
    Frag FixBot
  10. Samsung Galaxy A11 Vibration Motor Replacement, Vibration Motor: Schritt 10, Bild 1 von 2 Samsung Galaxy A11 Vibration Motor Replacement, Vibration Motor: Schritt 10, Bild 2 von 2
    • Using tweezers, remove the vibrator motor from the device.
    • If needed, you can apply heat to loosen the adhesive from the motor.
    Frag FixBot
Abschluss
Kristen Gismondi
107.106 Reputation
270 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
122 Mitglieder
25.856 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 5
Letzte 30 Tage: 19
Insgesamt: 408
