Einleitung
Use this guide to replace the back cover on a Galaxy A20. Check out this similar guide for a more detailed explanation.
Was du brauchst
Remove the SIM card and the SIM card tray.
Use an iOpener or heat gun to warm the adhesive that secures the back cover.
Insert an opening pick in the seam between the back cover and chassis while the adhesive is warm.
Slide the pick around the entire perimeter.
Remove the back cover.
Eine weitere Person hat diese Anleitung absolviert.
