Zum Hauptinhalt wechseln
Samsung Galaxy A20 Battery Replacement
Was du brauchst
  1. Samsung Galaxy A20 Battery Replacement, Back Cover: Schritt 1, Bild 1 von 3 Samsung Galaxy A20 Battery Replacement, Back Cover: Schritt 1, Bild 2 von 3 Samsung Galaxy A20 Battery Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Unplug and power off the device before beginning.
    • Remove the SIM card and the SIM card tray.
    • Use an iOpener or heat gun to warm the adhesive that secures the back cover.
    • Insert an opening pick in the seam between the back cover and chassis while the adhesive is warm.
    • Slide the pick around the entire perimeter.
    • If you encounter notable resistance, reheat the adhesive. Do not attempt to sever cold adhesive.
    • Remove the back cover.
    Frag FixBot
    Kommentar hinzufügen
  2. Samsung Galaxy A20 Battery Replacement, Battery: Schritt 2, Bild 1 von 2 Samsung Galaxy A20 Battery Replacement, Battery: Schritt 2, Bild 2 von 2
    • Remove all thirteen 3.6 mm Phillips screws that secure the midframe.
    • Use an opening pick to lift out the midframe.
    Frag FixBot
  3. Samsung Galaxy A20 Battery Replacement: Schritt 3, Bild 1 von 2 Samsung Galaxy A20 Battery Replacement: Schritt 3, Bild 2 von 2
    • Use an opening tool to gently pry up the press connectors on both ends of the two ribbon cables.
    • Remove the ribbon cables.
    Frag FixBot
  4. Samsung Galaxy A20 Battery Replacement: Schritt 4, Bild 1 von 2 Samsung Galaxy A20 Battery Replacement: Schritt 4, Bild 2 von 2
    • Apply a couple of drops of high-concentration isopropyl alcohol at the top of the battery to help loosen the adhesive that secures it.
    • Use an opening pick to gently pry up the battery.
    • Take care not to bend or puncture the battery.
    • Remove the battery.
    • During reassembly, if your new battery doesn't come with pre-applied adhesive, apply some to the well. Then, firmly press the new battery into place.
    Frag FixBot
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
There should be a caution for the fingerprint sensor to pop off the back cover before the next step or else someone might accidentally rip the ribbon cable off the sensor
Cybear6518 - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 48
Letzte 30 Tage: 180
Insgesamt: 3,762
