Einleitung
Replacing the speaker of your Samsung Galaxy A20 may be required due to various issues like water damage, trauma to the device, or sound output malfunctioning. This guide will give detailed instructions including how to remove your old speaker and replace it with a brand new one. Replacing the speaker can be challenging, but it is one of the simpler guides for this device. The difficulty mainly lies in the heat gun usage to initially take apart the device.
Special Skills
- Heat gun usage
Was du brauchst
Remove the SIM card and the SIM card tray.
Use an iOpener or heat gun to warm the adhesive that secures the back cover.
Insert an opening pick in the seam between the back cover and chassis while the adhesive is warm.
Slide the pick around the entire perimeter.
Remove the back cover.
