Einleitung
If your phone has been dropped and the glass or the LCD has broken, with this guide you can replace the display assembly of your Galaxy A20e and make it as good as new.
Was du brauchst
Release the back cover with the help of a thin blade or a Jimmy. Insert the tool between the frame display and the cover unclipping it along the entire perimeter.
Insert a Jimmy between the display frame and the side shell and slide it along the edge, in order to completely disengage the two parts.
Using a Philips #00 screwdriver, remove the 13 screws securing the inner cover.
Now you can remove the upper and lower covers that protect the logic board and the speaker respectively.
Pry up the following four connectors:
Battery connector;
Display connector;
Power / volume buttons;
Lower logic board connector.
Remove the battery by placing a few drops of alcohol underneath the battery and letting it sit for about a minute. This will weaken the double-sided adhesive that holds the battery.
Disconnect the two blue and white antenna wires.
Remove the motherboard by lifting it away by the upper part.
Carefully remove the microphone, as it is glued and easily damaged. Try to warm up that area a little to make it easier.
Remove the glued-on vibration motor with the help of a small amount of heat
Remove the lower motherboard.
Remove the glued-on speaker with the help of a heat source.
Once you have completed the component removal, you can begin the reassembly by placing the components on the new display.
16 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
12 Kommentare
this guide isn’t for a A20 its for an A20e
Ciao,il codice completo è A20E SM-A202f .
se cerchi questo codice nelle guide riparazione trovi telefono-Android-Samsung-A- A20e SM-A202f trovi la mia guida del display. Non posso nominarla come la cartella genitore,non so se questo è un bug. Grazie
Smilzo -
If you're gonna re-use the battery I wouldn't use heat, it damages the cells inside of the battery. Just pry with a spudger and have
I'm sorry I don't agree with a spudger without adequate heat the battery would bend to be removed. The adhesive is very resistant and the heat must be dosed appropriately for the situation so as not to damage the battery and the other components
Smilzo -
In another vid, to remove the battery “without" heat, the person used “rubbing alcohol” said it consumes the adhesive making it very easy to remove, placing it with a syringe like tip, along both the left and right sides, when the phone is in the normal upright position. And because rubbing alcohol evaporates, it's not harmful to the phone. Then a spudger can be used without brute force. That was a vid for the A205. (2019)
