Zum Hauptinhalt wechseln
Samsung Galaxy A3 2015 Glass / Touch Replacement
Was du brauchst
    • To complete the repair follow instructions from the tutorial. If you need any further info feel free to comment below the video.
Abschluss
17 weitere Nutzer:innen haben diese Anleitung absolviert.
Alex Sander
38.219 Reputation
202 Anleitungen geschrieben
5 Kommentare
I have a Galaxy A3 model. it fell in water while using it. It switched off then after some minutes it restarted but the screen started misbehaving like opening multiple apps on the phone. the following day the touch screen couldn’t respond but it was on showing my lockscreen but it wasn’t responding. I took it to repair and the guy told me the only option was replacing the whole screen… I dont know if thats the only option or if the glass is replaced could solve the problem.
MosesMaundu - Antwort
The technician i s probably right, you need to replace the whole display.
Alex Sander -
مانعرف ع
mohamed.marrof - Antwort
After separating the glass and the LCD there was lots of glue on the LCD. How did you remove it that it became so neat n clean???
Siamak - Antwort
Hi Siamak, you may try and get rid of the remaining adhesive with isopropyl alcohol (>97%)
Tobias Isakeit -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 24
Insgesamt: 4,128
