Was du brauchst
Einführungsvideo
Turn off the device by pressing and holding the small button on the right side. After a few seconds, press the Power Off button and wait until the device has completely shut off
To soften the adhesive, use a heat gun or heating pad to warm up the device.
Use a Spudger (Or playing card) , Suction Cup, and Isopropyl alcohol to separate the back cover.
Remove the SIM tray.
Remove the plastic cover that covers the Fingerprint flex connector.
Disconnect the Fingerprint Sensor.
Disconnect the Main flex cable, Display flex cable and the Coaxial antenna cable.
Remove the black screw securing the charging board.
Use Plastic tool to separate the charging board from the frame.
Now, install the new board and test the device.
2 weitere Personen haben diese Anleitung absolviert.
