Zum Hauptinhalt wechseln
Samsung Galaxy A40 Charging Board Replacement
Was du brauchst
Einführungsvideo
  1. Samsung Galaxy A40 Charging Board Replacement, Charging Dock / Charging Board: Schritt 1, Bild 1 von 2 Samsung Galaxy A40 Charging Board Replacement, Charging Dock / Charging Board: Schritt 1, Bild 2 von 2
    • The spare part: Daughter board with Charging port, Microphone, Main flex cable connector, display connector, 3G, 4G antennas
  2. Samsung Galaxy A40 Charging Board Replacement, Remove the Back Cover: Schritt 2, Bild 1 von 3 Samsung Galaxy A40 Charging Board Replacement, Remove the Back Cover: Schritt 2, Bild 2 von 3 Samsung Galaxy A40 Charging Board Replacement, Remove the Back Cover: Schritt 2, Bild 3 von 3
    • Turn off the device by pressing and holding the small button on the right side. After a few seconds, press the Power Off button and wait until the device has completely shut off
    • To soften the adhesive, use a heat gun or heating pad to warm up the device.
    • Use a Spudger (Or playing card) , Suction Cup, and Isopropyl alcohol to separate the back cover.
  3. Samsung Galaxy A40 Charging Board Replacement, Remove the  Sim Card Tray/Fingerprint Sensor: Schritt 3, Bild 1 von 3 Samsung Galaxy A40 Charging Board Replacement, Remove the  Sim Card Tray/Fingerprint Sensor: Schritt 3, Bild 2 von 3 Samsung Galaxy A40 Charging Board Replacement, Remove the  Sim Card Tray/Fingerprint Sensor: Schritt 3, Bild 3 von 3
    • Be very careful when removing the ribbons in this step! Damaging the ribbons may cause parts of your phone to stop working
    • Remove the SIM tray.
    • Remove the plastic cover that covers the Fingerprint flex connector.
    • Disconnect the Fingerprint Sensor.
  4. Samsung Galaxy A40 Charging Board Replacement: Schritt 4, Bild 1 von 3 Samsung Galaxy A40 Charging Board Replacement: Schritt 4, Bild 2 von 3 Samsung Galaxy A40 Charging Board Replacement: Schritt 4, Bild 3 von 3
    • Remove the 13 screws
    • Remove the back cover
  5. Samsung Galaxy A40 Charging Board Replacement: Schritt 5, Bild 1 von 2 Samsung Galaxy A40 Charging Board Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the Main flex cable, Display flex cable and the Coaxial antenna cable.
    • Remove the black screw securing the charging board.
  6. Samsung Galaxy A40 Charging Board Replacement: Schritt 6, Bild 1 von 3 Samsung Galaxy A40 Charging Board Replacement: Schritt 6, Bild 2 von 3 Samsung Galaxy A40 Charging Board Replacement: Schritt 6, Bild 3 von 3
    • Use Plastic tool to separate the charging board from the frame.
    • Warm the charging board slightly to make it easier to disassemble.
    • Now, install the new board and test the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
ZFix
191.368 Reputation
330 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
321 Mitglieder
1.468 Anleitungen geschrieben
Ein Kommentar
Replaced port but phone now doesn't recognise sim can use WhatsApp though
Ann Sayer - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 32
Letzte 30 Tage: 118
Insgesamt: 5,532
