Einleitung
Samsung Galaxy A51 - how to disassemble the device and change broken screen
Was du brauchst
Einführungsvideo
Warm up the device to soften the adhesive.
Use suction cup and plastic tools (playing cards) to separate the back cover.
Disconnect and remove the main flex cable.
To remove the fingerprint sensor - remove two Philips screws and disconnect the flex cable.
Disconnect coaxial antenna cable.
Remove the Sub -board? Charging board.
The motherboard is secured by one small black screw, remove it to separate the board.
Don't forget to transfer the receiver.
10 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Hallo, i made repleacment, display went well ( touch and functions, but after turning on the display was like in shadow and side lines were on white kind a yellow fade, what it could be? is it by bad replacement, display or something else?
