Zum Hauptinhalt wechseln
Samsung Galaxy A72 Screen with Frame Replacement
Was du brauchst
Einführungsvideo
  1. Samsung Galaxy A72 Screen with Frame Replacement, Back cover removal: Schritt 1, Bild 1 von 3 Samsung Galaxy A72 Screen with Frame Replacement, Back cover removal: Schritt 1, Bild 2 von 3 Samsung Galaxy A72 Screen with Frame Replacement, Back cover removal: Schritt 1, Bild 3 von 3
    • Warm the device to soften the adhesive.
    • To separate the back cover, use plastic tools, a suction cup and a little ethanol alcohol.
  2. Samsung Galaxy A72 Screen with Frame Replacement: Schritt 2, Bild 1 von 3 Samsung Galaxy A72 Screen with Frame Replacement: Schritt 2, Bild 2 von 3 Samsung Galaxy A72 Screen with Frame Replacement: Schritt 2, Bild 3 von 3
    • Remove the SIM Tray.
    • Unscrew the silver Phillips screws and remove the motherboard plastic cover.
  3. Samsung Galaxy A72 Screen with Frame Replacement, Motherboard removal: Schritt 3, Bild 1 von 3 Samsung Galaxy A72 Screen with Frame Replacement, Motherboard removal: Schritt 3, Bild 2 von 3 Samsung Galaxy A72 Screen with Frame Replacement, Motherboard removal: Schritt 3, Bild 3 von 3
    • Disconnect the battery.
    • Disconnect the main flex cable.
    • Disconnect the Coaxial antenna cables.
    • Remove the black Philips screw securing the motherboard to the display frame.
    • Keep in mind this screw is different from the others.
    • Use a plastic tool to remove the Motherboard.
  4. Samsung Galaxy A72 Screen with Frame Replacement, Daughter board part 1: Schritt 4, Bild 1 von 3 Samsung Galaxy A72 Screen with Frame Replacement, Daughter board part 1: Schritt 4, Bild 2 von 3 Samsung Galaxy A72 Screen with Frame Replacement, Daughter board part 1: Schritt 4, Bild 3 von 3
    • Remove the silver Phillips screws and with a plastic tool lift up the plastic cover.
  5. Samsung Galaxy A72 Screen with Frame Replacement, Daughter board part 2: Schritt 5, Bild 1 von 3 Samsung Galaxy A72 Screen with Frame Replacement, Daughter board part 2: Schritt 5, Bild 2 von 3 Samsung Galaxy A72 Screen with Frame Replacement, Daughter board part 2: Schritt 5, Bild 3 von 3
    • Disconnect the fingerprint sensor.
    • Disconnect the Main flex cable.
    • Remove the black screw securing the Charging board.
    • Keep in mind that this screw is different from the others.
    • Use a plastic tool and gently pick up the Daughter board.
    • Be carefully for the Fingerprint sensor flex cable.
  6. Samsung Galaxy A72 Screen with Frame Replacement: Schritt 6, Bild 1 von 3 Samsung Galaxy A72 Screen with Frame Replacement: Schritt 6, Bild 2 von 3 Samsung Galaxy A72 Screen with Frame Replacement: Schritt 6, Bild 3 von 3
    • Remove the Motor Vibrator.
    • Remove the Fingerprint sensor.
    • Do it slowly and carefully.
    • Before assembling the phone, test the new display using this code:
    • *#0*#
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
ZFix
191.497 Reputation
330 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
321 Mitglieder
1.485 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 20
Letzte 30 Tage: 88
Insgesamt: 4,596
