Zum Hauptinhalt wechseln
Samsung Galaxy Alpha Micro USB port Replacement
Was du brauchst
  1. Samsung Galaxy Alpha Micro USB port Replacement, Removing the Back Panel: Schritt 1, Bild 1 von 3 Samsung Galaxy Alpha Micro USB port Replacement, Removing the Back Panel: Schritt 1, Bild 2 von 3 Samsung Galaxy Alpha Micro USB port Replacement, Removing the Back Panel: Schritt 1, Bild 3 von 3
    • On the back panel of the phone, find the slot that is on the top left side next to the flashlight.
    • Insert your fingernail or prying tool into the slot and lift up to slightly open the top left corner of the back panel.
    • Slide your fingernail or prying tool around the outer edge of the back panel to fully release it from the phone.
  2. Samsung Galaxy Alpha Micro USB port Replacement, Battery: Schritt 2, Bild 1 von 2 Samsung Galaxy Alpha Micro USB port Replacement, Battery: Schritt 2, Bild 2 von 2
    • Make sure the device is powered down before moving forward.
    • Since the NFC antenna is glued to the battery, make sure the replacement also includes one.
    • Locate the slot at the base of the battery and insert your thumb.
    • Push slightly toward the battery and out, away from the phone to free the battery.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ryan Butler
1.695 Reputation
9 Anleitungen geschrieben
iFixit, Team 1-1, Weber Winter 2016 Mitglied von iFixit, Team 1-1, Weber Winter 2016
FIX-WEBER-W16S1G1
4 Mitglieder
37 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 131
