Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Remove the speaker/rear camera assembly from the Samsung Galaxy Attain 4G. This assembly includes the vibrator, rear-facing camera, flash, and loudspeaker.
  1. Begin by turn the device over to it's back, with the screen facing down.
    • Begin by turn the device over to it's back, with the screen facing down.
  2. At the top of the device there is a small notch that is used to remove the battery door. Using a pry tool or your fingernail, pry off the battery door from the main housing.
    • At the top of the device there is a small notch that is used to remove the battery door.
    • Using a pry tool or your fingernail, pry off the battery door from the main housing.
  3. Place the battery door to the side. Using a pry tool or your fingernail, pry the battery up towards you. You have now removed the battery!
    • Place the battery door to the side.
    • Using a pry tool or your fingernail, pry the battery up towards you.
    • You have now removed the battery!
  4. Make sure when replacing the battery that the arrow on the bottom is facing down.
    • Make sure when replacing the battery that the arrow on the bottom is facing down.
  5. Remove the 6 Phillips head screws that hold the rear housing in place.
    • Remove the 6 Phillips head screws that hold the rear housing in place.
  6. Using a spudger or plastic pry tool, slowly go around the phone between the display & rear housing to release the clips.
    • Using a spudger or plastic pry tool, slowly go around the phone between the display & rear housing to release the clips.
  7. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  8. Lift the rear housing from the display assembly.
    • Lift the rear housing from the display assembly.
  9. Using your spudger/plastic pry tool, disconnect the headphone jack flex cable. Using your spudger/plastic pry tool, disconnect the headphone jack flex cable.
    • Using your spudger/plastic pry tool, disconnect the headphone jack flex cable.
  10. Using your spudger/plastic pry tool, disconnect the rear speaker flex cable. Using your spudger/plastic pry tool, disconnect the rear speaker flex cable.
    • Using your spudger/plastic pry tool, disconnect the rear speaker flex cable.
  11. Using a spudger/pry tool, carefully remove the vibration motor from its housing. This has a mild adhesive on the bottom.
    • Using a spudger/pry tool, carefully remove the vibration motor from its housing. This has a mild adhesive on the bottom.
  12. After removing both flex cables, slowly move the logic board to the left of the screen assembly. Do not try and remove the logic board all the way, as you still have to remove the display assembly flex cable!
    • After removing both flex cables, slowly move the logic board to the left of the screen assembly.
    • Do not try and remove the logic board all the way, as you still have to remove the display assembly flex cable!
  13. Using your spudger/plastic pry tool, disconnect the LCD/Digitizer flex cable.
    • Using your spudger/plastic pry tool, disconnect the LCD/Digitizer flex cable.
  14. You have now removed the logic board from the display assembly. You have now removed the logic board from the display assembly.
    • You have now removed the logic board from the display assembly.
  15. Flip the logic board to the rear side, and using a spudger/plastic pry tool to disconnect the rear camera flex cable. Flip the logic board to the rear side, and using a spudger/plastic pry tool to disconnect the rear camera flex cable.
    • Flip the logic board to the rear side, and using a spudger/plastic pry tool to disconnect the rear camera flex cable.
  16. Flip the logic board to the front, and using a spudger/plastic pry tool to push the tension clip away from the board that holds the speaker/rear camera.
    • Flip the logic board to the front, and using a spudger/plastic pry tool to push the tension clip away from the board that holds the speaker/rear camera.
  17. Flipping the board back over, remove the speaker/rear camera by lifting from the right side as shown.
    • Flipping the board back over, remove the speaker/rear camera by lifting from the right side as shown.
    • Be careful not to rip the ribbon cable when you disconnect the speaker/rear camera cable connector.
  18. The speaker/rear camera has now been removed from the board.
    • The speaker/rear camera has now been removed from the board.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Josh Forester
2.335 Reputation
10 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 158
