Zum Hauptinhalt wechseln
Samsung Galaxy Camera Battery Replacement
Was du brauchst
  1. Samsung Galaxy Camera Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Lift aside the casing for the battery using a plastic opening tool. This compartment is on the bottom of the camera, not under the lens.
    • The casing is highlighted in the red markup circle.
  2. Samsung Galaxy Camera Battery Replacement: Schritt 2, Bild 1 von 1
    • The slot for the battery should look like this. This is the case for the battery.
  3. Samsung Galaxy Camera Battery Replacement: Schritt 3, Bild 1 von 2 Samsung Galaxy Camera Battery Replacement: Schritt 3, Bild 2 von 2
    • Using plastic opening tool, slide battery capture latch back and allow battery to fall out.
    • Insert your replacement battery.
  4. Samsung Galaxy Camera Battery Replacement: Schritt 4, Bild 1 von 2 Samsung Galaxy Camera Battery Replacement: Schritt 4, Bild 2 von 2
    • After the battery has been replaced, close the battery casing.
    • Now replace the casing from step one. Success, the battery has been replaced!
Abschluss
These steps follow completely: there is no need to reverse the order of steps to reassemble.
8 weitere Personen haben diese Anleitung absolviert.
Derek Brown
168 Reputation
1 Anleitung geschrieben
IUPUI, Team 2-3, Wilson Fall 2015 Mitglied von IUPUI, Team 2-3, Wilson Fall 2015
IUPUI-WILSON-F15S2G3
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 52
Insgesamt: 3,006
