Zum Hauptinhalt wechseln
Samsung Galaxy Camera Camera Flash Replacement
Was du brauchst
  1. Samsung Galaxy Camera Camera Flash Replacement, Screen: Schritt 1, Bild 1 von 1
    • Begin removing the 3/16" screws for the device.
  2. Samsung Galaxy Camera Camera Flash Replacement: Schritt 2, Bild 1 von 1
    • Turn the device and remove the additional 3/16" screws.
  3. Samsung Galaxy Camera Camera Flash Replacement: Schritt 3, Bild 1 von 1
    • Turn the device and remove the additional 3/16" screw.
  4. Samsung Galaxy Camera Camera Flash Replacement: Schritt 4, Bild 1 von 3 Samsung Galaxy Camera Camera Flash Replacement: Schritt 4, Bild 2 von 3 Samsung Galaxy Camera Camera Flash Replacement: Schritt 4, Bild 3 von 3
    • Take the white cover plate off.
  5. Samsung Galaxy Camera Camera Flash Replacement: Schritt 5, Bild 1 von 1
    • Using the plastic opening tools, pry open the camera from the bottom.
    • This may require a moderate use of force because of the sealing glue.
  6. Samsung Galaxy Camera Camera Flash Replacement: Schritt 6, Bild 1 von 1
    • Gently pull the connector away from the motherboard.
  7. Samsung Galaxy Camera Camera Flash Replacement, Lens and Motherboard: Schritt 7, Bild 1 von 1
    • Unscrew the motherboard's screws. There are 4 3/32" screws and 3 5/32" screws.
  8. Samsung Galaxy Camera Camera Flash Replacement: Schritt 8, Bild 1 von 1
    • Unscrew the lens' screws. There are 1 black 4/32" screw, 3 3/16" black screws, and 2 white 5/32" screws.
  9. Samsung Galaxy Camera Camera Flash Replacement: Schritt 9, Bild 1 von 1
    • Pull these connectors away from motherboard.
  10. Samsung Galaxy Camera Camera Flash Replacement: Schritt 10, Bild 1 von 1
    • Lift the motherboard and lens out of the case.
  11. Samsung Galaxy Camera Camera Flash Replacement, Unscrew: Schritt 11, Bild 1 von 1
    • Remove all the screws circled. There is 1 1/8" screw by the flash, 1 9/32" screw that holds the flash button, 2 5/32" screw that is on the grey frame for the flash, and 2 5/32" screws that holds the cable frames on the top left.
  12. Samsung Galaxy Camera Camera Flash Replacement: Schritt 12, Bild 1 von 1
    • Unscrew the 3 5/32" screws that cover the battery plate.
  13. Samsung Galaxy Camera Camera Flash Replacement: Schritt 13, Bild 1 von 1
    • The black plates on the other side can be removed after these screws.
  14. Samsung Galaxy Camera Camera Flash Replacement: Schritt 14, Bild 1 von 1
    • Pull the flash and battery case out of the device.
Abschluss
13 weitere Personen haben diese Anleitung absolviert.
Richard Hicks
1.280 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 1-3, Sullivan Winter 2015 Mitglied von USF Tampa, Team 1-3, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G3
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 876
