Zum Hauptinhalt wechseln
Samsung Galaxy Camera Lens and Motherboard Replacement
Was du brauchst
  1. Samsung Galaxy Camera Lens and Motherboard Replacement, Screen: Schritt 1, Bild 1 von 1
    • Begin removing the 3/16" screws for the device.
  2. Samsung Galaxy Camera Lens and Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Turn the device and remove the additional 3/16" screws.
  3. Samsung Galaxy Camera Lens and Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Turn the device and remove the additional 3/16" screw.
  4. Samsung Galaxy Camera Lens and Motherboard Replacement: Schritt 4, Bild 1 von 3 Samsung Galaxy Camera Lens and Motherboard Replacement: Schritt 4, Bild 2 von 3 Samsung Galaxy Camera Lens and Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Take the white cover plate off.
  5. Samsung Galaxy Camera Lens and Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Using the plastic opening tools, pry open the camera from the bottom.
    • This may require a moderate use of force because of the sealing glue.
  6. Samsung Galaxy Camera Lens and Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Gently pull the connector away from the motherboard.
  7. Samsung Galaxy Camera Lens and Motherboard Replacement, Lens and Motherboard: Schritt 7, Bild 1 von 1
    • Unscrew the motherboard's screws. There are 4 3/32" screws and 3 5/32" screws.
  8. Samsung Galaxy Camera Lens and Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Unscrew the lens' screws. There are 1 black 4/32" screw, 3 3/16" black screws, and 2 white 5/32" screws.
  9. Samsung Galaxy Camera Lens and Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Pull these connectors away from motherboard.
  10. Samsung Galaxy Camera Lens and Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Lift the motherboard and lens out of the case.
Abschluss
10 weitere Personen haben diese Anleitung absolviert.
Richard Hicks
1.280 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 1-3, Sullivan Winter 2015 Mitglied von USF Tampa, Team 1-3, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G3
3 Mitglieder
Ein Kommentar
Hey mate, what do you do after the motherboard replacement? Just turn the camera on? Do you need to do a master reset?
Sam - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 20
Insgesamt: 5,198
