Zum Hauptinhalt wechseln
Samsung Galaxy Camera Lens or Motherboard Replacement
Was du brauchst
  1. Samsung Galaxy Camera Lens or Motherboard Replacement, Lens or Motherboard: Schritt 1, Bild 1 von 1
    • Gather your camera and tools. Also make sure that the battery is removed before proceeding.
    • Follow battery replacement guide through step three to remove the battery.
  2. Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 2, Bild 1 von 3 Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 2, Bild 2 von 3 Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Remove all seven 4 millimeter long screws using the PH000 screwdriver bit.
  3. Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 3, Bild 1 von 2 Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Use plastic opening tool to remove the cover on the non-lens side of the camera.
  4. Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 4, Bild 1 von 3 Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 4, Bild 2 von 3 Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Open the battery compartment and remove the 2 screws. Also remove the screw from the bottom of the camera after pulling off the white sticker concealing it. Removing these screws releases the bottom of the display assembly.
    • Starting at the non-lens side of the camera, use plastic opening tool to pry screen away from main housing on all sides.
  5. Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 5, Bild 1 von 2 Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Use plastic opening tool to pull connector away from motherboard.
    • Remove screen completely and set aside.
  6. Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 6, Bild 1 von 2 Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Using the plastic opening tool, disconnect the three connectors from the motherboard.
  7. Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Remove the three 3.5 mm long screws (red circle markers) using the PH000 screwdriver bit.
    • Remove the four 2 mm long screws (orange circle markers) using the PH000 screwdriver bit.
  8. Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 8, Bild 1 von 2 Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Remove the three 3 mm long screws connecting the lens unit to the main housing using the PH000 screwdriver bit.
    • Carefully remove the lens and motherboard from main housing.
  9. Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 9, Bild 1 von 3 Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 9, Bild 2 von 3 Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Remove stickers off of connectors.
    • Open latch door on connectors.
    • Separate lens from motherboard.
    • Now you may replace either motherboard or lens with new part.
Abschluss
9 weitere Personen haben diese Anleitung absolviert.
IUPUI, Team 2-3, Wilson Fall 2015 Mitglied von IUPUI, Team 2-3, Wilson Fall 2015
IUPUI-WILSON-F15S2G3
4 Mitglieder
4 Anleitungen geschrieben
2 Kommentare
Would love a video of this, as well.
David CrossmN - Antwort
Hey after you replace the motherboard do you just turn the camera on and it works?
Ive done it and some chinese characters show up in a dialog box...
Sam - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 3,568
