Was du brauchst
Remove the central frame to access the motherboard, help yourself with a thin tool
Remove the black screw that secures the lower motherboard
Unclip the 3 connectors
Disconnect the connection cable of the 2 motherboards
With a flat instrument, help yourself to unhook the motherboard
Remove top motherboard
Remove Speaker
Remove the lower motherboard with the help of a hot air hairdryer to help it detach from the adhesive
If the touch screen glass is broken, use tape to avoid injury
Disconnect the TouchScreen connector
Remove the touchscreen with thin tools between the glass and the central cover with the aid of a hair dryer or heat so that you can loosen the adhesive grip
Be careful in the part of the buttons and the flat cable of the touchscreen if you need to use it again and do not replace it with a new one
To Reassemble your device, Follow these instruction reverse order.
3 weitere Personen haben diese Anleitung absolviert.
100%
irlanda hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
