Einleitung
Samsung Galaxy CORE, DUOS (i8260, i8262) - how to disassemble the phone and remove the Logic Board.
_________________ Video tutorial: _________________
Was du brauchst
Einführungsvideo
Switch-off the phone.
Remove the Battery cover and the battery.
Remove an inserted SIM and Memory cards.
Remove 9x Phillips screws.
With a plastic tool remove the Back cover.
The Vibrator is on the other side of the back cover
Disconnect one by one:
Earpiece/Loudspeaker/Audio Jack connector module flex cable
LCD Display flex cable
Charging Dock/Antenna/Mic module flex cable
Coaxial Antenna cable
Carefully remove the Logic Board.
11 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
I like this apps
Thank your so much.
