Zum Hauptinhalt wechseln
Einleitung
Samsung Galaxy CORE, DUOS (i8260, i8262) - how to disassemble the phone and replace Main and Front Cameras.
_________________ Video tutorial: _________________
Ersatzteile
Keine Ersatzteile angegeben.
Einführungsvideo
  1. Switch-off the phone. Remove the Battery cover and the battery.
    • Switch-off the phone.
    • Remove the Battery cover and the battery.
    • Remove an inserted SIM and Memory cards.
  2. Remove 9x Phillips screws. With a plastic tool remove the Back cover. The Vibrator is on the other side of the back cover
    • Remove 9x Phillips screws.
    • With a plastic tool remove the Back cover.
    • The Vibrator is on the other side of the back cover
  3. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Jetzt kaufen
    iPhone X Fix Kits
    Jetzt kaufen
  4. Disconnect one by one: Earpiece/Loudspeaker/Audio Jack connector module flex cable LCD Display flex cable
    • Disconnect one by one:
    • Earpiece/Loudspeaker/Audio Jack connector module flex cable
    • LCD Display flex cable
    • Charging Dock/Antenna/Mic module flex cable
    • Coaxial Antenna cable
    • Carefully remove the Logic Board.
  5. Main / Rear Camera Front Camera With a plastic tool open the Camera flex cable connector.
    • Main / Rear Camera
    • Front Camera
    • With a plastic tool open the Camera flex cable connector.
    • Carefully remove the camera.
Abschluss
7 weitere Nutzer haben diese Anleitung absolviert.
ZFix
165.707 Reputation
305 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
287 Mitglieder
811 Anleitungen geschrieben
Hi, I have galaxy win and the front camera is too bad in quality, i want to replace front camera with galaxy core front camera which is very descent in compare to galaxy win. Please suggest
My email Id: shaikhyassar@gmail.com
Yassar Shaikh - Antwort
اكتب عربي
Mjd Mjd - Antwort
My mobile Sony m2 my camera low quality... Can I do anything for this problem??!
Mjd Mjd - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 4,002
