Zum Hauptinhalt wechseln
Samsung Galaxy Core Plus Battery Replacement
Was du brauchst
  1. Samsung Galaxy Core Plus Battery Replacement, Back Cover: Schritt 1, Bild 1 von 2 Samsung Galaxy Core Plus Battery Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Insert the flat side of a spudger into the gap next to the power button.
    • The back cover is held by plastic clips. Pry the cover away from the phone until the clips release.
  2. Samsung Galaxy Core Plus Battery Replacement: Schritt 2, Bild 1 von 3 Samsung Galaxy Core Plus Battery Replacement: Schritt 2, Bild 2 von 3 Samsung Galaxy Core Plus Battery Replacement: Schritt 2, Bild 3 von 3
    • Insert an opening pick between the phone and the back cover.
    • Slide the opening pick along the perimeter of the cover.
    • Continue to release the clips by prying away from the phone.
  3. Samsung Galaxy Core Plus Battery Replacement: Schritt 3, Bild 1 von 2 Samsung Galaxy Core Plus Battery Replacement: Schritt 3, Bild 2 von 2
    • Once all of the clips have been released, remove the back cover by hand.
  4. Samsung Galaxy Core Plus Battery Replacement, Battery: Schritt 4, Bild 1 von 3 Samsung Galaxy Core Plus Battery Replacement, Battery: Schritt 4, Bild 2 von 3 Samsung Galaxy Core Plus Battery Replacement, Battery: Schritt 4, Bild 3 von 3
    • Insert the flat end of a spudger into the gap at the bottom of the battery.
    • Pry the battery up and away from the phone.
    • Grab the battery and lift it out of the phone.
Abschluss
Clay Eickemeyer
313 Reputation
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 71
