Einleitung
A problem you may find with your Samsung Galaxy Core Prime is a scratched camera lens. Instead of buying an entirely new phone you can instead replace the camera. For this guide you will need an iOpening tool, a metal spudger, a Phillips #00 screwdriver, or similarly shaped tools.
Was du brauchst
Turn the smartphone off by using the power button on the right-hand side.
Locate the battery near the bottom of the phone. The battery is square, flat, and is labeled 'SAMSUNG'.
Use a Phillips #00 screw driver to remove all eight 4mm screws from the midframe.
In diesem Schritt verwendetes Werkzeug:iFixit Opening Tool$1.99
Use the iFixit Opening tool to pry off the midframe.
Disconnect the power ribbon on the left side of the phone either with your fingers or tweezers
Lift the motherboard from the phone with an iFixit Opening Tool.
In diesem Schritt verwendetes Werkzeug:Metal Spudger$2.99
Turn the Motherboard over and disconnect the ribbon connecting the camera to the Motherboard with an iFixit Metal Spudger.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
