Einleitung
This guide will enable you to replace the screen in case of broken glass, failure to respond, etc. You will need a heat gun, Phillips #00 screwdriver, iFixit opening tool, and tweezers. Take care when using dangerous tools.
Was du brauchst
Turn the smartphone off by using the power button on the right-hand side.
Locate the battery near the bottom of the phone. The battery is square, flat, and is labeled 'SAMSUNG'.
Use the Phillips #00 screwdriver to remove the eight 4 mm screws from the midframe.
Use a heat gun or hair dryer to loosen the adhesive between the midframe and the rest of the device.
In diesem Schritt verwendetes Werkzeug:iFixit Opening Tool$1.99
Use the iFixit Opening Tool to lift the frame.
Use the iFixit Opening Tool to remove the mother board.
Lift the plastic panel that separates the digitizer and the motherboard with an iFixit Opening Tool
Use a heat gun and an iFixit Opening Tool tool to separate the screen from the digitizer.
7 weitere Personen haben diese Anleitung absolviert.
