Zum Hauptinhalt wechseln
Samsung Galaxy Core Prime Screen Replacement
Was du brauchst
  1. Samsung Galaxy Core Prime Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the smartphone off by using the power button on the right-hand side.
  2. Samsung Galaxy Core Prime Screen Replacement: Schritt 2, Bild 1 von 1
    • Turn the smartphone over so that the rear camera is face up.
  3. Samsung Galaxy Core Prime Screen Replacement: Schritt 3, Bild 1 von 1
    • Use your fingernail or a flat tool to lift the back cover.
  4. Samsung Galaxy Core Prime Screen Replacement: Schritt 4, Bild 1 von 2 Samsung Galaxy Core Prime Screen Replacement: Schritt 4, Bild 2 von 2
    • Locate the battery near the bottom of the phone. The battery is square, flat, and is labeled 'SAMSUNG'.
  5. Samsung Galaxy Core Prime Screen Replacement: Schritt 5, Bild 1 von 1
    • Use your fingernail or a flat tool to lift the battery out.
  6. Samsung Galaxy Core Prime Screen Replacement, Screen: Schritt 6, Bild 1 von 2 Samsung Galaxy Core Prime Screen Replacement, Screen: Schritt 6, Bild 2 von 2
    • Use the Phillips #00 screwdriver to remove the eight 4 mm screws from the midframe.
  7. Samsung Galaxy Core Prime Screen Replacement: Schritt 7, Bild 1 von 1
    • Use a heat gun or hair dryer to loosen the adhesive between the midframe and the rest of the device.
    • Take care when using these heat tools.
  8. Samsung Galaxy Core Prime Screen Replacement: Schritt 8, Bild 1 von 2 Samsung Galaxy Core Prime Screen Replacement: Schritt 8, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    iFixit Opening Tool
    $1.99
    Kaufen
  9. Samsung Galaxy Core Prime Screen Replacement: Schritt 9, Bild 1 von 2 Samsung Galaxy Core Prime Screen Replacement: Schritt 9, Bild 2 von 2
    • Use tweezers to disconnect the power ribbon from the motherboard.
  10. Samsung Galaxy Core Prime Screen Replacement: Schritt 10, Bild 1 von 2 Samsung Galaxy Core Prime Screen Replacement: Schritt 10, Bild 2 von 2
    • Use tweezers or your hand to remove the audiojack.
  11. Samsung Galaxy Core Prime Screen Replacement: Schritt 11, Bild 1 von 1
    iFixit Opening Tool
    $1.99
    Kaufen
  12. Samsung Galaxy Core Prime Screen Replacement: Schritt 12, Bild 1 von 1
    iFixit Opening Tool
    $1.99
    Kaufen
    • Lift the plastic panel that separates the digitizer and the motherboard with an iFixit Opening Tool
  13. Samsung Galaxy Core Prime Screen Replacement: Schritt 13, Bild 1 von 3 Samsung Galaxy Core Prime Screen Replacement: Schritt 13, Bild 2 von 3 Samsung Galaxy Core Prime Screen Replacement: Schritt 13, Bild 3 von 3
    iFixit Opening Tool
    $1.99
    Kaufen
  14. Samsung Galaxy Core Prime Screen Replacement: Schritt 14, Bild 1 von 2 Samsung Galaxy Core Prime Screen Replacement: Schritt 14, Bild 2 von 2
    • Use tweezers to disconnect the digitizer.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Cody Coombs
257 Reputation
1 Anleitung geschrieben
Sam Houston State, Team S11-G2, Blackburne Fall 2018 Mitglied von Sam Houston State, Team S11-G2, Blackburne Fall 2018
SHSU-BLACKBURNE-F18S11G2
4 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
What if the phone does not come back on after assembly
nfl.ny.la.313 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 38
Insgesamt: 2,485
