Einleitung
Users will be able to replace lost, broke, or scratched volume control buttons for the Samsung Galaxy Core Prime. This will enable the user to more easily control volume and improve the overall aesthetics of the smartphone.
Was du brauchst
Turn the smartphone off by using the power button on the right-hand side.
Locate the battery near the bottom of the phone. The battery is square, flat, and is labeled 'SAMSUNG'.
Use a Phillips #00 screwdriver to remove the eight 4mm screws from the midframe.
Flip the phone over (screen up). Use an iOpener to heat the frame. Do this until the adhesive is loose.
Use an iFixit Opening Tool or a similarly shaped tool like a guitar pick to lift the mid-frame.
Use tweezers to unhook both of the rubber fixtures holding the volume button to the frame.
2 weitere Personen haben diese Anleitung absolviert.
