Einleitung
Don't panic if the back or recent tabs button stops working; just follow this relatively simple guide to replace them. You will need to remove the screen.
Was du brauchst
Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone.
Once the cover is removed, locate the battery that reads "SAMSUNG."
Use either your fingernail or a Plastic Prying Tool (such as a guitar pick) to lift up the bottom indent of the battery.
Use a Thin Plastic Tool (such as a guitar pick) or Plastic Prying Tool (such as a spudger) to lift out the glass digitizer and LCD screen around the edges.
Use a plastic tool to remove back and/or recent tabs circuit buttons.
