Zum Hauptinhalt wechseln
Samsung Galaxy Express 3 Motherboard Replacement
Was du brauchst
  1. Samsung Galaxy Express 3 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 2 Samsung Galaxy Express 3 Motherboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone.
  2. Samsung Galaxy Express 3 Motherboard Replacement: Schritt 2, Bild 1 von 3 Samsung Galaxy Express 3 Motherboard Replacement: Schritt 2, Bild 2 von 3 Samsung Galaxy Express 3 Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Once the cover is removed, locate the battery that reads "SAMSUNG."
    • Use either your fingernail or a Plastic Prying Tool (such as a guitar pick) to lift up the bottom indent of the battery.
    • Do not use a metal tool, as it can cause injury.
  3. Samsung Galaxy Express 3 Motherboard Replacement, Screen: Schritt 3, Bild 1 von 2 Samsung Galaxy Express 3 Motherboard Replacement, Screen: Schritt 3, Bild 2 von 2
    • Use a Plastic Prying Tool (such as a spudger) to pop out piece shown.
  4. Samsung Galaxy Express 3 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Detach the screen connector.
  5. Samsung Galaxy Express 3 Motherboard Replacement: Schritt 5, Bild 1 von 2 Samsung Galaxy Express 3 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Use a blow dryer or heating pad to heat up the screen.
    • Do not skip this step, as it may result in a broken screen and/or LCD.
    • This step loosens the glue holding the screen in place.
  6. Samsung Galaxy Express 3 Motherboard Replacement: Schritt 6, Bild 1 von 3 Samsung Galaxy Express 3 Motherboard Replacement: Schritt 6, Bild 2 von 3 Samsung Galaxy Express 3 Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Use a Thin Plastic Tool (such as a guitar pick) or Plastic Prying Tool (such as a spudger) to lift out the glass digitizer and LCD screen around the edges.
    • Do this slowly and carefully, as both parts can crack very easily.
    • Ensure your tool is plastic, as a metal tool can damage the screen easily.
  7. Samsung Galaxy Express 3 Motherboard Replacement, Motherboard: Schritt 7, Bild 1 von 2 Samsung Galaxy Express 3 Motherboard Replacement, Motherboard: Schritt 7, Bild 2 von 2
    • Remove the nine screws with a Phillips #0 screwdriver.
  8. Samsung Galaxy Express 3 Motherboard Replacement: Schritt 8, Bild 1 von 2 Samsung Galaxy Express 3 Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Using a spudger to remove the black plastic pieces on the top and bottom of the screen.
    • Do not use a metal tool, as it can be dangerous to you or the motherboard.
    • Use caution when removing the top black piece, as it is wedged tightly in the phone and can be easily broken.
  9. Samsung Galaxy Express 3 Motherboard Replacement: Schritt 9, Bild 1 von 2 Samsung Galaxy Express 3 Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Remove the one black screw located below the bottom plastic piece.
    • This is the only screw of this size, so make sure to keep it separate.
  10. Samsung Galaxy Express 3 Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Use a spudger to slowly lift up the motherboard and remove it from the plastic frame.
    • If you cannot remove the motherboard with ease, this means that all screws have not been removed.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 13
Insgesamt: 1,230
