Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
  1. Turn the phone off and make sure your hands are clean. Use your thumb nail or a plastic spudger to pry open the back cover,
    • Turn the phone off and make sure your hands are clean. Use your thumb nail or a plastic spudger to pry open the back cover,
  2. Use the plastic opening tool or your thumb nail to lift the battery out of the receptacle.
    • Use the plastic opening tool or your thumb nail to lift the battery out of the receptacle.
  3. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  4. Remove the five 4 mm screws with a Phillips#00 screwdriver. Make sure you remove the sticker hiding the screw on the left bottom corner. Make sure you remove the sticker hiding the screw on the left bottom corner.
    • Remove the five 4 mm screws with a Phillips#00 screwdriver.
    • Make sure you remove the sticker hiding the screw on the left bottom corner.
  5. Using the plastic opening tool pry into the bezel to remove the mid-frame Continue moving the plastic opening tool around the mid-frame to separate it from the display assembly.
    • Using the plastic opening tool pry into the bezel to remove the mid-frame
    • Continue moving the plastic opening tool around the mid-frame to separate it from the display assembly.
    • Be gentle the plastic mounting clips are very fragile. Pay extra attention when working around the volume button.
  6. After separating the two frames, you will have access to the camera
    • After separating the two frames, you will have access to the camera
  7. Pull the camera off the system by using the tweezers. Perform this step with caution.
    • Pull the camera off the system by using the tweezers. Perform this step with caution.
Abschluss
6 weitere Nutzer haben diese Anleitung absolviert.
Charles
133 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 8-2, Leahy Fall 2014 Mitglied von USF Tampa, Team 8-2, Leahy Fall 2014
USFT-LEAHY-F14S8G2
4 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 4
Insgesamt: 865
