Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Ersatzteile
Keine Ersatzteile angegeben.
  1. Make sure that the phone is turned off. Then use your thumb nail or a plastic spudger to pry open the back cover.
    • Make sure that the phone is turned off. Then use your thumb nail or a plastic spudger to pry open the back cover.
  2. Use your thumb nail or the plastic opening tool to lift the battery out of the device.
    • Use your thumb nail or the plastic opening tool to lift the battery out of the device.
  3. Remove the five 4 mm screws with a Phillips#00 screwdriver Note: One of the five screws is hidden under a sticker on the bottom left corner of the device.
    • Remove the five 4 mm screws with a Phillips#00 screwdriver
    • Note: One of the five screws is hidden under a sticker on the bottom left corner of the device.
  4. Use the plastic opening tool to pry into the bezel to separate the mid-frame from the device Be gentle; the plastic mounting clips are very fragile. Take extra care when working around the volume button.
    • Use the plastic opening tool to pry into the bezel to separate the mid-frame from the device
    • Be gentle; the plastic mounting clips are very fragile. Take extra care when working around the volume button.
  5. Use the Phillips#00 screwdriver to remove the five black screws. Use the plastic opening tool to lift the two ribbons. Remove the metal internal cover to expose the motherboard.
    • Use the Phillips#00 screwdriver to remove the five black screws.
    • Use the plastic opening tool to lift the two ribbons.
    • Remove the metal internal cover to expose the motherboard.
  6. Use the plastic opening tool to lift the motherboard out of the device.
    • Use the plastic opening tool to lift the motherboard out of the device.
  7. Once you have removed the motherboard you will have access to the LCD screen. Use the plastic opening tool to remove the damaged LCD screen from the display assembly.
    • Once you have removed the motherboard you will have access to the LCD screen.
    • Use the plastic opening tool to remove the damaged LCD screen from the display assembly.
    • Put the new LCD screen in place and reassemble the device.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Sarah Brueck
125 Reputation
1 Anleitung geschrieben
USF Tampa, Team 8-2, Leahy Fall 2014 Mitglied von USF Tampa, Team 8-2, Leahy Fall 2014
USFT-LEAHY-F14S8G2
4 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 912
